External Interfaces
This section describes the supported external API interfaces.
REST API
As of Release 8.0, the Oracle Communications Session Delivery Manager supports a REST API interface, allowing northbound client applications to interact with OCSDM and its supported product plugins. For information on supported REST APIs and how to use the REST API Interface, see the REST API for Session Delivery Manager guide.
SOAP API
With the introduction of OCSDM, Release 8.0, the SOAP API client is provided for backwards compatibility only. The SOAP API will not support any new APIs for new OCSDM enhancements. Oracle recommends using the REST API for OCSDM if you require access to new OCSDM features via a programmatic API.
