Session Element Manager Features Delivered by the Enterprise Edge and Core Plug-in Release 2.0 and 2.1
The following features are described for the Enterprise Edge and Core plug-in for Releases 2.0 and 2.1 and where they are documented.
| Feature | Release | Description | Where Documented |
| Fraud Protection Manager (FPM) | 2.0 | FPM allows the user to manage
Fraud Protection Lists (FPLs). An FPL contains lists of phone numbers to block,
allow, redirect, and limit the rate of calls.
Rules are configured in Fraud Protection Manager to handle fraudulent traffic and activate fraudulent phone lists by sending a single request to activate them on multiple southbound devices. Once an FPL is applied to an ESBC device, the device is protected against fraudulent calls. |
Refer to the new Fraud Protection Manager chapter in the Oracle® Communications Session Element Manager User Guide for the Enterprise Edge and Core Plug-in for more information. |
| Renaming of existing OCSEM Plug-ins | 2.0 | In this release, the Enterprise plug-in is now the Enterprise Edge and Core plug-in. | Refer to the
Session Element Manager Plug-in Support
Matrix section for more information.
Also, the Oracle Service Provider Edge and Core Plug-in Product Category and Network Function Types section was added to Device Manager chapter in the Oracle Communications Session Element Manager User Guide for the Enterprise Edge and Core Plug-in. |
| Enterprise Edge and Core Plug-in FDP Support | 2.1 |
Support for configuring the Fraud Protection feature was added with the introduction of the Enterprise Edge and Core Plug-in Release 2.1. This support includes the ability to register OCSDM with an FDP device for communication with southbound devices that support the Fraud Protection feature. In order for the Fraud Protection feature to be used, you must also install the Enterprise Utilities plug-in. |
See the Oracle Communications Session Element Manager User Guide for Enterprise Edge and Core Plug-in and Oracle Communications Session Element Manager User Guide for Enterprise Utilities for more information. |
