Session Delivery Manager Installation
Use this chapter to quickly review Oracle Communications Session Delivery Manager system requirements, high-level prerequisites, and the required software distribution media that you must download before you install OCSDM on your system(s).
Refer to the
Delivery Manager Installation Guide for the following
installation information:
- Perform pre-requisite tasks, such as configuring firewall settings, checking Linux support and Linux version dependencies, and ensuring that the SDM_localhost Entry is configured in the Hosts File.
- Configure your NNCentral account.
- Choose the type of OCSDM installation that you want to do (Typical, Custom, Easy Install, Headless Install).
- Perform a new OCSDM installation or upgrade.
- Perform specific setup instructions for each OCSDM installation type.
You must be running OCSDM Release 7.5M3 or 8.0 to upgrade to 8.1. If you are running any release prior to 7.5M3, you must upgrade to 7.5M3 before you can upgrade to 8.1.
