New Session Element Manager Plug-in Device Software Support
The following table describes new device software support for the Oracle Communications Session Element Manager plug-in releases which have occurred since the introduction of OCSDM 8.0.
Refer to the Plug-in Support Matrix section for more information about what plugin is used with the product device releases mentioned below. All plugins inherit the support of the previous release, including the device releases mentioned in the Historical Session Element Manager Device Software Support section.| OCSEM Plug-in Name | Release Introduced | Devices |
AcmeSD |
1.0 |
SP Edge and Core |
2.0 |
Enterprise |
1.0 |
Enterprise Edge and Core |
2.0 |
2.1 |
EnterpriseExt |
1.0 |
Enterprise Utilities |
2.0 |
2.1 |
Footnote 1 S-Cz8.2.0 is used for both Service Provider and Enterprise SBCs with this plugin running on SDM 8.1.1.
