Session Element Manager Features Delivered by the Service Provider Plug-in
The Service Provider (SP) Edge and Core plug-in (formerly called the AcmeSD plug-in) contains the Oracle Communications Session Element Manager (OCSEM) application, which is used to manage and optimize network infrastructure elements and their functions for the following:
- Oracle Communications Session Border Controller (SBC)
- Oracle Communications Subscriber-Aware Load Balancer (SLB)
- Oracle Communications Mobile Security Gateway (MSG)
- Oracle Communications Unified Session Manager (USM)
- Subscriber-aware Load Balancing and Route Management (SLRM)
- Oracle Communications Session Router (OCSR)
- product devices with comprehensive tools and applications on the OCSDM (OCSDM)
The OCSEM can also provision fault, configuration, accounting, performance, and security (FCAPS) support for managed devices. Upon installation of the plug-in, OCSEM sliders and any Report Manager and Route Manager co-product sliders appear. For information on supported sliders and devices, see Oracle Communications Session Element Manager User Guide for the Service Provider Edge and Core Product Plug-in.
The AcmeSD plug-in name changes to SP Edge and Core in its second version.
