PreviousNextJavaScript must be enabled to correctly display this content
Revision History
Date
Description
July 2018
Initial release
September 2018
An entry for
customer defect 28557993 was added to the Known Issues section.
October 2018
With the
introduction of
Oracle Communications Session
Delivery Manager (OCSDM) Release 8.1.1, a
Fraud Detection and Prevention (FDP) device is now supported by
OCSDM and the Enterprise
Edge & Core Release 2.1 Plug-in and the Enterprise Utilities Release 2.1
Plug-in.
Updates the list
of supported Operating Systems to include Oracle Linux 6.9.
Renames the "REST
examples in documentation" feature in "Release 8.1 Features" to "REST API" and
includes information on SOAP API support.
Consolidates the
"SEM Features Delivered by the Enterprise Edge and Core plugin Release 2.0" and
"SEM Features Delivered by the Enterprise Edge and Core plugin Release 2.1"
sections.
Updates the
description of the
SOAP API Guide in "Related Documentation" to
remove statement about SOAP deprecation. This update has been made globally
across the
Delivery Manager, Oracle Communications Session Element Manager, Oracle
Communications Route Manager, and Oracle Communications Report Manager
documentation sets.
Adds a note to
"Session Element Manager Features Delivered by the Service Provider Edge and
Core Plug-in Release 2.0" containing conceptual information regarding
OCSDM's use of Network
Functions (NFs).
December 2018
Updates "New
Session Element Manager Plug-in Device Software Support" in conjunction with
the OCSBC 8.2 release.
May 2019
Updates "New
Session Element Manager Plug-in Device Software Support" to remove ECz8.1M1
from the list of supported devices in Enterperise Edge and Core 2.1.
December 2019
Adds Caveat
regarding upgrading under the Enterprise Edge & Core category.
