User Group Privileges
In Oracle Communications Session Delivery Manager, user group privileges can be applied to user groups that you add to allow or deny all users within this user group the ability to perform certain operations. This includes items intended for use with separate application products. For the default LIAdministrators, administrators, provisioners, and monitor user groups, only device group privileges can be changed.
User group privileges that are assigned to either the administrators or LIAdministrators user groups inherit most of the same access privileges. However, users assigned to the LIAdministrators user group have full configuration privileges to manage the Configure LI element (Lawful Intercept) in the Device configuration subfolder within the Configuration folder in the Configuration tab. Users assigned to administrators, provisioners and monitors default user groups do not have privileges to configure the Configure LI element.
If Lawful Intercept (LI) is enabled on a device that OCSDM manages, LI configuration values become encrypted on this device and OCSDM.
