Start the Oracle Database Software Installer
Log in as the oracle user with the -Y flag.
ssh -Y oracle@vm
Navigate to the
/app/oracledirectory.cd /app/oracle
Unzip the Oracle database software installer.
If necessary, installunzipwith the commandyum install unzip.unzip linux.x64_11gR2_database_1of2.zip unzip linux.x64_11gR2_database_2of2.zip
Set the TMP, TMPDIR, and ORACLE_BASE variables and unset the ORACLE_HOME variable.
export TMP=/tmp export TMPDIR=/tmp export ORACLE_BASE=/app/oracle unset ORACLE_HOME
Navigate to the
/app/oracle/databasedirectory.cd /app/oracle/database/
Run the Oracle database software installer.
./runInstaller
If you experience errors, see the X11 Forwarding section of the Troubleshooting chapter.
