Free Up Disk Space In local clusters, dump files may be deleted if the server runs low on disk space. Note:Do not run this command if a backup or restore is in progress. Log in as the oracle user. Find and remove the dump files. find . -name OCSDMDW_Dump*.dmp | xargs rm –rf
