PreviousNextJavaScript must be enabled to correctly display this content
Oracle Database Installer Errors
If you receive an error that says the Oracle Net Configuration
Assistant failed or there is an invalid specification for system parameter
LOCAL_LISTENER ORA-00130, ensure your
/etc/hosts file
contains a valid hostname besides "localhost."
