xdpyinfo Errors
The following error messages indicate that xdpyinfo is not installed:
- Checking monitor: must be configured to display at least 256 colors
- Could not execute auto check for display colors using command /usr/bin/xdpyinfo. Check if the DISPLAY variable is set. Failed.
