PreviousNextJavaScript must be enabled to correctly display this content
Create the Boot Properties File
The post-installation process involves the creation of a
boot.properties file.
Change directories
to the BI Publisher domain. For example:
cd /app/OracleMiddleWare/user_projects/domains/bifoundation_domain
If the following
path does not exist on your system, create it with the mkdir command.
Otherwise, change directories from the BI Publisher domain to
servers/AdminServer/security.
For example:
cd servers/AdminServer/security
Create a file
called boot.properties.
vi boot.properties
Add the following
two lines:
username=weblogic
password=<password>
Use the password which you created for the weblogic user.
