Shutdown Report Manager
- Log in as the nncentral user.
Change the
directory to the bin directory.
For example:
cd /home/nncentral/AcmePacket/NNC<version>/bin
Execute the
shutdownnnc.sh
script. By default, the shutdownnnc.sh script detects whether the existing
installation is a standalone or clustered system and prompts you with the
option to shutdown the entire cluster if no flag options are provided.
However, you can script an option ahead of time by adding -local for single nodes and - cluster to shutdown an entire cluster../shutdownnnc.sh Shutdown back-end server Do you wish to shut down the entire cluster (Yes/No)? Yes
- On the server where the Oracle database software and BI Publisher are installed, login as the Oracle user.
Change to the
WebLogic server directory:
[oracle@vm ~]$ cd /app/OracleMiddleWare/user_projects/domains/bifoundation_domain/bin/
Stop the WebLogic
server by running the
stopWebLogic.shscript.[oracle@vm bin]$ ./stopWebLogic.sh
Stop the BI
Publisher database instance listener (LISTENER).
./lsnrctl stop
Stop the OCSDMDW
database instance listener (LISTENER2):
./lsnrctl stop LISTENER2
If undefined, set
the ORACLE_HOME variable in the .bash_profile of both the oracle user and the
nncentral user.
export ORACLE_HOME=/app/oracle/product/11.2.0/dbhome_1
Specify the
ORACLE_SID variable for the AcmeBIPublisher database.
export ORACLE_SID=AcmeBIPublis
Execute the
ORACLE_HOME/bin/sqlplus script.
[oracle@vm bin]$ ./sqlplus '/ as sysdba'
Use the following
option to shutdown the Oracle database instance and exit:
SQL> shutdown immediate; SQL> exit
Specify the
ORACLE_SID variable for the Report Manager database instance (OCSDMDW).
export ORACLE_SID=ocsdmdw
Execute the
Use the following
