Hourly Summary Reports
Hourly summary reports may occasionally generate errors for some devices.
If hourly summary reports are not displaying properly:
- Log into BIPublisher as an administrator.
- Click Administrative and navigate to Runtime Configuration, Properties.
- Select the Properties tab and find the Memory Guard section of the table.
- Find the elements that are
generating errors and update their default values with new values. After 30
seconds the changes are enabled. A restart of the BIPublisher is not required.
Repeat this process until the reports display properly.
