Execute Configuration Scripts to Access the Oracle Database Software The Execute Configuration scripts dialog box opens to display the location of scripts that must be run by the root user before continuing. Open a separate terminal window and login to the server as the root user. Run the following scripts displayed in the following Execute Configuration scripts dialog box in the separate terminal window that you opened: cd /home/oracle/app/oraInventory/ ./orainstRoot.sh cd /home/oracle/app/oracle/product/12.2.0/dbhome_1/ ./root.sh The Execute Configuration scripts dialog box displays the scripts you need to execute to create the Oracle database: When you execute the scripts, you are prompted with the following message: Do you want to setup Oracle Trace File Analyzer (TFA) now ? yes|[no] : Press enter to select the default (no). Note: If you need to setup the Oracle Trace File Analyzer for collecting diagnostic data and resolving issues, type yes and press Enter. Go back to the Execute Configuration scripts dialog box, and click OK. Continue to monitor the Install Product window. When the installation finishes, the Finish window appears and tells you that the installation was successful. Click Close . The Oracle database is created and can now be reached at https://<localhost>:5500/em.
