PreviousNextJavaScript must be enabled to correctly display this content
Select the GUI Installer Method
Select either X11 forwarding using secure shell (SSH) or the virtual network computing (VNC) to do installations with a graphical user interface (GUI) installer on your Linux system.
Configure SSH with X11
Forwarding
You can use either
the -X or -Y flag to enable X11 forwarding through SSH when you log in as the
root user. For example:
ssh –Y root@server-name
If you do not
have DNS on your server or the server name does not work, enter the IP address
of the server.
(Optional) Install
the
xorg-x11-xauth package
(if it is not already installed). For example:
