About This Guide
This document and other product-related documents are described in the Related Documentation table.
Oracle Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
Table - Oracle Communications Product Plug-in Documentation Library
| Document Name | Description |
| Session Element Manager User Guide | Provides information for managing and optimizing network infrastructure elements and their functions with comprehensive tools and applications used to provision fault, configuration, accounting, performance, and security (FCAPS) support for managed network functions and their associated devices in Oracle Communications Session Delivery Manager (SDM). |
| Report Manager User Guide |
Provides information about configuring Report Manager to interoperate with Oracle BI Publisher as well as creating reports on Session Delivery product network devices. |
| Report Manager Installation Guide | Provides information for installing Oracle Communications Report Manager product as an addition to SDM including the Oracle database and BI Publisher components. The Oracle session delivery product plugin must be added to Oracle Communications Session Delivery Manager before performing the Report Manager installation. |
| Route Manager User Guide |
Provides information for updating local route table (LRT) data on a single device or multiple devices. |
Table - Oracle Communications Session Delivery Manager Documentation Library
| Document Name | Document Description |
| Administration Guide | Provides the following
administration information:
| Installation Guide | Provides the following
installation information:
| Release Notes | Contains information about the administration and software configuration of the SDM feature support new to this release. |
| Security Guide | Provides the following security
guidelines:
| REST API Guide | Provides information for the supported REST APIs and how to use the REST API interface. The REST API interface allows a northbound client application, such as a network service orchestrator (NSO), to interact with SDM and its supported product plugins. |
| SOAP API Guide |
The SOAP API guide provides information for the SOAP and XML provisioning Application Programming Interface (API) client and server programing model that enables users to write client applications that automate the provisioning of devices. The web service consists of operations that can be performed on devices managed by the SDM server and data structures that are used as input and output parameters for these operations. |
