Pre-Installation Tasks
Read and understand the summary of pre-installation steps that need to be done before installing Oracle® Communications Report Manager on your Oracle Communications Session Delivery Manager system.
The Oracle® Communications Report Manager for Oracle Fusion Middleware 12c installation is a new, clean installation. The previous Report Manager databases are not upgraded.- Check Linux server requirements before installing the required software.
- Decide if you are going to implement Oracle® Communications Report Manager in a local or remote configuration.
- Create an Oracle group and user account on your Linux system(s).
- Select either X11 forwarding using secure shell (SSH) or the virtual network computing (VNC) to install the Oracle database and BI Publisher software with a graphical user interface (GUI) installer on your Linux system.
