Add Reports to a Favorites List
The Favorites region enables you to create your own list of reports for quick access. From the Favorites region you can view, schedule, configure, or edit the objects that you place there (providing you also have proper permissions).
There are several ways to add objects to the Favorites region:
- Locate the object in the catalog, click the More link, and then click Add to Favorites.
- From the Report Viewer, click the Actions menu, and then click Add to Favorites.
- Use the Manage link on the Home page to add reports.
To add and delete reports from the Favorites region, click the Manage link to open the Favorites area for editing.
To add a report to Favorites:
- Click the report in the catalog pane.
- Drag the report to the Favorites region.
To delete an object from Favorites:
- Locate the item and click the More link.
- Click Remove.
