Aggregating Data
The configured push receiver uses FTP/SFTP to push the CSV files to the SDM server on which the Report Manager application runs. Before Report Manager can aggregate the data, it must identify new files, add them to a files table, and load them into the reporting database.
Data Type Aggregation Behavior
Below is a table of data types, and the aggregation behavior for each type.
| Data Type | Aggregation Behavior |
| Dimension | Dimensions cannot be aggregated |
| Identifiers | Identifiers cannot be aggregated |
| State | The most recent state value |
| Boolean | The most recent boolean value |
| Count | The sum of the integer values |
| Range (i.e. 0-100) | The average of all values |
| Current value | The average of all values |
| Capacity | The average of all values |
| Index | The most recent index value |
| High water mark | The maximum value |
| Maximum rate | The maximum value |
| Low water mark | The minimum value |
| Minimum rate | The minimum value |
| Percentage | The average of all percentage values |
| Rate | The average of all rate values |
| Latency | The average of all latency values |
| Ratio | The average of all ratios |
| Speed | The average of all speeds |
| Temperature | The average of all temperatures |
