Search for Route Set Backups You can search for route set backups based on name only, name and date and time, or on date and time. Expand the Route Manager slider, and click Backup/Restore. In the Route Set Backups tab, click Search. In the Backup Search dialog box, complete the following fields to configure your search criteria: Name field The name of the route set backup. Starting at field and drop-down list The start date in YYYY-MM-DD format or click the calendar icon to select the date. Next, select the time of day from the drop-down list. Ending at field and drop-down list The end date in YYYY-MM-DD format or click the calendar icon to select the date. Next, select the time of day from the drop-down list. Click Search. The results display in the table. You can optionally click Show All to re-display all backups.
