PreviousNextJavaScript must be enabled to correctly display this content
Add a New Route Set
A route set is a container of routes and information
about these routes such as their public identifier (PUB ID) and other
information, such as the number of hops for a route and so on. Route sets are
used to update LRT data on device groups that use an LRT file.
Expand the
Route
Manager slider, and click
Route
sets.
In the
Route
sets tab, click
Add.
In the
Add Route
Set dialog box, complete the following fields:
Route Set Type field
The
SBC radio button is
selected by default for the Session Border Controller (SBC) route set type. The
DSC option is deprecated.
Name field
The name for the new route set using
alphanumeric characters without spaces.
Device LRT configuration
name field
The configuration name of the local route
table (LRT) associated with the route set. This value must match the configured
name on the device.
Device LRT file name
field
The name used for this LRT file, which must
match the LRT file name in the device configuration and select its extension.
The default file extension is
.xml.gz.
pub-id type
drop-down list
(Required) Select the public identifier in the
form of a telephone number or prefix (for example, NPA-NXX) used in LRT lookup
for this route set.
Description field
(Optional) Enter a description for this route
set.
Notes field
(Optional) Enter a note for this route set.
Populate from existing route
set drop-down list
(Optional) Use the parameters of a
pre-existing route set.
