Manage Reusable Configuration Modules
View Reusable Configuration Modules
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).Update a Network Function Device Configuration
Pre-requisites: You must apply the RCM to a device before you can save and activate changes. See the Apply an RCM to a Device section for more information.
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).- Expand the Configuration Manager slider, and select Devices.
- In the Managed Devices table, navigate the folder hierarchy to the network function (NF) device, and click Update.
In the update
dialog, choose from the following options:
(Default) Select Save & activate configuration to save the configuration and make the current working configuration on the device the running configuration.
Select Save configuration to save the current working configuration changes to the device.
Select Activate configuration to make the current working configuration the running configuration.
Delete an Element from an Existing Reusable Configuration Module
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).- Expand the Configuration Manager slider, and select Configuration Tools, Reusable Modules.
- Select the RCM, and click Load.
- Select the element you want to delete from the Elements defined table, and click Delete.
- In the confirmation dialog, click OK.
Reusable Configuration Module Input Wizard Configuration: Example
The following example shows how input values are entered in the RCM Input wizard screen for an SIP Trunk service RCM.
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).Delete a Reusable Configuration Module
An RCM is deleted only if it is not assigned to any device or configuration with a dependency. When the RCM is deleted, it is permanently removed from the database and cannot be retrieved.
For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC).- Expand the Configuration Manager slider, and select .
- In the Reusable Configuration module table, select the RCM you want to delete, and click Delete.
- In the Delete confirmation dialog, click Yes.
