PreviousNextJavaScript must be enabled to correctly display this content
Revision History
Date
Description
July 2018
Initial release
October 2018
With the
introduction of the Oracle Enterprise Edge and Core Plug-in Release 2.1, a
Fraud Detection and Prevention (FDP) device is now supported.
Removes note
stating Fraud Detection and Prevention device support is unavailable.
Adds "Update Fraud
Protection List Changes Manually When Automatic Updates are Enabled" section.
Adds note to the
"Add a Fraud Detection and Prevention Device Registration" and "Edit a Fraud
Detection and Prevention Device Registration" sections stating requirements for
the Username parameter.
Adds conceptual
information to "Oracle Enterprise Edge and Core Plug-in Product Category and
Network Function Types" regarding
OCSEM's use of
Network Functions (NFs).
