Configure a Device Cluster with an Offline Configuration
You add a device cluster, which can contain a single device group or multiple device groups and associate it with a single offline configuration that you added. All targeted devices in the device cluster must share the same software version, and platform.
Add a Device Cluster Network Function
Pre-requisite: If you are not using the default Home group to add a device cluster NF, you must specify a device group. See the Configure Device Groups section in the Device Manager chapter for more information.
Associate the device cluster with its offline configuration.
Associate a Device Cluster with an Offline Configuration
Once you have added a device cluster to an NF, the device cluster must be associated with an offline configuration.
Pre-requisites: You must add an offline configuration before you associate the device cluster with an offline configuration. See the Add an Offline Configuration section for more information.
Add a Device to a Device Cluster
Now that you have associated a device cluster to its offline configuration you can add devices to the device cluster.
- The device must contain a platform and software version that matches the Offline Configuration.
 - The device must be accessible through SSH over the network.
 - The device has all required entitlements enabled, and licenses installed, as needed, to provide any services enabled by the Offline Configuration.
Ensure that any device that is added to the cluster is not currently being managed by OCSEM. If a device is being managed by OCSEM, remove it from OCSEM so that you can add it to the device cluster.
