View Sumary Data
The following summary data can include general SDM system-level information (for example, the local date and time (with time zone adjustment) of the SDM server), key performance indicator (KPI) data, or data retrieved for NF devices managed by Oracle Communications Session Element Manager. When you expand the Dashboard Manager slider and select Summary view, the Summary pane displays summary information for all active and standby devices similar to what is shown in the following figure:
Figure 10-1 Dashboard Manager Summary View
The following portals are displayed:
- Managed Devices—A list of all managed devices by either IP address or host name.
- Top 20 Alarm Counts—Key performance indicators (KPI) for the alarm (fault) status summary for each device.
- Health Scores—A graphical pie chart that represents the health score of devices. Green is 75-100, yellow is 50 to 74, and red is any score below 50.
- Top 20 CPU Usage—A list of the top 20 devices that display based on their CPU usage.
- Top 20 Memory Usage—A list of the top 20 devices that display based on their memory usage.
- Top 20 Call Rate—A list of the top 20 devices that display based on the number of calls and concurrent sessions on each device.
- Logged In Users—A list of users logged into SDM with session start times and locations (IP addresses).
Refresh Data
- Expand the Dashboard Manager slider and select Summary view.
- At the top of the Summary pane, click Refresh to update the whole dashboard summary view.
Configure Auto Refresh
- Click Auto refresh.
- In the Auto refresh dialog box, enter the number of seconds for when the page contents update.
- Click OK.
View Managed Device Data
View Alarm Summary Data
- In the Device column of the Managed Devices table, select the device you want to view. In the Alarm Summary table, a bar chart displays the alarm counts for all alarm categories for your device. You can mouse over a bar within the chart for the number of alarms that bar represents. See the Change the Default Severity Alarm Colors section in the Security Manager chapter for more information.
- Click Refresh to update alarm summary data.
- Click View Alarms to view alarm data in Fault Manager.
- Click Back to return to the main summary view display.
View Top 20 Alarm Counts
- In the Top 20 Alarm Counts dialog box, a summary of the top 20 devices with generated alarms that include EMERGENCY, CRITICAL and MAJOR designations. You can position your mouse over each device to see additional information for the device.
