Add a New Reusable Configuration Module from an Existing Software Model Schema Note:For Oracle Enterprise products, the following procedure supports only the Enterprise Session Border Controller (ESBC). Expand the Configuration Manager slider and select Configuration Tools, Reusable Modules. In the Reusable Configuration module pane, click Add. Name field The unique name of the RCM. Description field The RCM description. Modifiable drop-down list Select from the following user permissions: Select public to allow any user to modify this RCM. Select private to allow only the creator of the RCM to modify this RCM. Category field Click the ellipsis (...) button to select the product plug-in vendor category: In the Select network function type dialog box, select the NF type. Click Select. Component field This field populates with Default (NF component) when the product plug-in vendor category is selected. Platform drop-down list Select the platform of the device software on which the RCM is based. Supported software version drop-down list Select the device software version on which the RCM is based. Click Apply.
