Manage Software Work Orders
Configure a Software Downgrade Work Order
Use the same tasks in the Configure a Software Upgrade Work Order section if you need to do a software downgrade across a group of targeted devices. The only difference is you must add a previous version of the software image to the software image archive directory and select this software image later when you add the software downgrade work order. The limitation is that some device downgrades may not supported. See your device product documentation for more information.
