Add a Software Image to the Software Image Archive Directory
The software image archive allows you to view, load and delete all device software images maintained by the Oracle Communications Session Element Manager.
Before you create your software upgrade work order, you must upload the correct software image to the software image archive on the server directory:
/home/nncentral/AcmePacket/NNCArchive/SWImageArchive
If the Oracle Communications Session Delivery Manager server on which Oracle Communications Session Element Manager is in a cluster, this server ensures that the new image is replicated for all nodes in the cluster.
