Configure Fraud Protection Lists
Fraud Protection Lists (FPLs) are used and created to protect individuals from fraudulent calls.
You can add, edit, import, upload and copy an FPL, manage FPL list entries, and assign and re-synchronize an FPL with a Fraud Detection and Prevention (FDP) device. You can also schedule a specific time to push an FPL to an associated southbound device.
Import a Fraud Protection List
You can create a new Fraud Protection List (FPL) file by importing the contents of an existing template configuration FPL file from a local file that has an .xml, .gz, or .gzip format.
Upload a Fraud Protection List from a Device
You can create a new Fraud Protection List (FPL) file by importing an FPL file from an existing device.
Pre-requisites: Before you choose a device as the realm source, you must first add and load this device in Configuration Manager. Refer to the Associate Devices with Session Element Manager section for more information.
Copy Fraud Protection List Contents to Another Fraud Protection List
Assign Fraud Detection and Prevention Device to a Fraud Protection List
You can assign a single registered Fraud Detection and Prevention (FDP) device to one or multiple Fraud Protection Lists (FPLs).
Unassign Fraud Detection and Prevention Device to a Fraud Protection List
You can unassign a single registered Fraud Detection and Prevention (FDP) device from one or multiple Fraud Protection Lists (FPLs).
- Expand the Fraud Protection Manager slider, and click Fraud protection list.
- In the FPL management tab, select an FPL from the FPL table and click Un-assign.
- In the confirmation dialog box, click Yes.
- In the Success dialog box, click OK.
