Configure and Apply a Reusable Configuration Module
A Reusable Configuration Module (RCM) is a work flow template that describes a sequence of configuration changes that are used to deploy a feature on a device. An RCM can be applied without having to modify the top-level configuration elements because it targets specific parameters, and does not require a clustered device environment or a specific software version.
An RCM can use an existing device schema model and be associated with device configurations by inputting values for the specified variables. This abstracts the end user from the model schema, allowing for the configuration of specific functionality without knowledge of the element topology.
Oracle Communications Session Element Manager modifies the specified attributes in the target configuration to the values contained within the RCM.
An RCM can be applied to any supported Oracle Communications Session Delivery product device software model.The following preexisting RCMs are included with Oracle Communications Session Element Manager:
| Name | Description |
| rcmAddSLRMtoASBC | Adds an Oracle Communications SLRM to an Oracle Communications ASBC configuration. |
| rcmRemoveSLRMfromCSM | Removes an Oracle Communications SLRM from an Oracle Communications Core Session Manager configuration. |
| rcmRemoveSLBfromSBC | Removes an Oracle Communications Subscriber-Aware Load Balancer from an Oracle Communications Session Border Controller configuration. |
| rcmAddSLBtoSBC | Adds an Oracle Communications Subscriber-Aware Load Balancer to an Oracle Communications Session Border Controller configuration. |
| rcmAddSBCtoSR | Adds an Oracle Communications Session Border Controller to an Oracle Communication Session Router configuration. |
| rcmRemoveSLRMfromASBC | Removes an Oracle Communications SLRM from an Oracle Communications ASBC configuration. |
| rcmRemoveSBCfromSR | Removes an Oracle Communications Session Border Controller from an Oracle Communications Session Router configuration. |
| rcmAddSLRMtoCSM | Registers an Oracle Communications SLRM with an Oracle Communications Core Session Manager configuration. |
