Predefine Variable Values for an Element in a Reusable Configuration Module
- Expand the Configuration Manager slider, and select Configuration Tools, Reusable Modules.
- Select the RCM that you want to modify, and click Load.
- Select the element you want to edit from the Elements defined table, and click Edit.
- Enter a pre-defined input value for each attribute name.
- Repeat until all required variables are defined.
- Click Apply.
- Click OK.
