Add an Offline Configuration
You can either add an offline configuration by copying a managed device configuration or from an existing supported software schema in OCSEM.
Add an Offline Configuration from a Managed Device
You can seed a configuration from a from an existing managed device configuration.
Load the new offline configuration and modify any of the pre-populated base parameters, as needed for your domain.
Add an Offline Configuration from a Software Version
You can seed a configuration from a supported software version schema.
Add an Offline Configuration by Copying a Template
Use this task to copy an existing offline configuration or a pre-packaged offline configuration template to make a new offline configuration for your domain.
