Upload a Configuration Schema for a Device
You can use this task to manually upload the configuration schema when the Oracle Communications Session Element Manager cannot get the configuration schema (XSD file) from the device.
All software release configuration information is modeled
		  and maintained in a valid configuration schema for a device so that it can be
		  managed by
		  OCSEM. Most often, a
		  software release schema is matched for a device, which is required so that the
		  device can be assigned in Configuration Manager. If a software release is not
		  found,
		  OCSEM attempts to get the
		  configuration schema directly from the device (in recent device releases, the
		  configuration schema is packaged with the release image), and put it in the
		  database local schema repository.
If the schema for a device does not exist for a software release, the device can be added to Device Manager but cannot be managed by OCSEM.- On the menu bar, select Tools, Upload configuration schema file.
 - In the Upload configuration schema file dialog, select the product plug-in category (for example, SP Edge & Core) from the Categories table for the product plug-in.
 - Click Browse, and navigate to a valid configuration schema file on your system.
 - In the File Upload dialog, select the configuration schema you want to upload, and click Open.
 - In the Upload configuration schema file dialog, click Upload to start the upload process.
 - In the success dialog, click OK.
