Execute a Software Upgrade Work Order Manually
Once the software upgrade work order is created and its configuration is applied, it can be executed manually (unless you previously scheduled a start date and time for it to execute).
- Expand the Device Manager slider and select .
 - In the Work orders table, select the work order you want to execute and click Start.
 - In the confirmation dialog box, click Yes.
 - Click Refresh to confirm the status changes for your software upgrade work order from Not Scheduled to Running.
