System
System: General Tab
| CPU utilization (%) | The total percentage of CPU utilization measured in one second. |
| CPU Application load rate | The average load rate of the service applications taken over a period of up to 10 seconds. |
| Memory utilization (%) | The percentage of memory utilization. |
| CAM utilization (%) - media | The percentage of network address translation (NAT) table (in content addressable memory (CAM)) utilization. |
| CAM utilization (%) - ARP | The percentage of address resolution protocol (ARP) table (in CAM) utilization. |
| License capacity | The percentage of licensed sessions currently in progress. |
| Health score (%) | The system health percentage ( a value of 100 (percent) is the healthiest). |
| Redundancy state | The information about the state of each
device in an HA pair. Values are:
| Current signaling sessions (SIP, H.323, and MGCP) | The total number of global concurrent sessions at the moment. |
| Current signaling rate (SIP, H.323, and MGCP) (CPS) | The number of global calls per second. |
| I2C bus state | State of the environmental monitor located
in the chassis. The values are:
Identification Tab
| System name | The administratively-assigned name for this node. By convention, this is the node's fully-qualified domain name. If the name is unknown, the value is the zero-length string. |
| System contact | The text identification of the contact person for this node, together with information on how to contact this person. If no contact information is known, the value is the zero-length string. |
| System location | The physical location of this node. If the location is unknown, the field is left blank. |
| System description | The text description of the entity. This value includes the full name and version identification of the system's hardware type, software operating-system, and networking software. |
| System objectID | The vendor's authoritative identification of the network management subsystem contained in the entity. This value is allocated within the SMI enterprises subtree (1.3.6.1.4.1) and provides an easy and unambiguous means for determining what kind of box is being managed. |
| System uptime | The time (in hundredths of a second) since the network management portion of the system was last re-initialized. |
