Manage Software Work Orders
Delete a Software Image from the Software Image Archive Directory
  1. Expand the Device Manager slider and select Software upgrade > Software image archive.
  2. Select the software image file you want to delete from the archive home directory and click Delete.
  3. In the success dialog box click OK.
    The software image file is removed from the Software Image Archive table.
Configure a Software Downgrade Work Order
Use the same tasks in the Configure a Software Upgrade Work Order section if you need to do a software downgrade across a group of targeted devices. The only difference is you must add a previous version of the software image to the software image archive directory and select this software image later when you add the software downgrade work order. The limitation is that some device downgrades may not supported. See your device product documentation for more information.
