Manage Device Configurations
View Managed Devices
When you want to view the details about the configuration of a managed device, use the Devices object in Configuration Manager to display a list of managed devices with the corresponding configuration parameters.
Update a Device Configuration
Pre-requisites: Before you update a device configuration you must first load it in Configuration Manager. See the Load the Configuration of a Local Device to Configure a Device section for more information.
Track Device Configuration Changes
Use this task to track changes that are made to device parameters.
- Expand the Configuration Manager slider, and click the Devices folder.
- In the Managed Devices table, expand the folder hierarchy, select a network function (NF) device, and click Get Inventory.
- In the Configuration inventory dialog that appears for the device, review the number of each type of configuration element.
- (Optional) Click Save to file.
- In the dialog that appears, click OK to download the information in the format of a comma-separated values (CSV) file to your system.
View Device Tasks
- In the Managed Devices table, expand the folder hierarchy, select a network function (NF) device, and click View tasks.
- In the Device tasks table, you can view the device operations that are performed and if you select a device operation row, you can see logs for this device operation by clicking View Log.
Export Detailed Device Information from Configuration Manager
You can export network function (NF) device information to your local system, which allows data to be saved in a table-structured format for auditing or management purposes.
- Expand the Configuration Manager slider, and click Devices.
- In the Managed Devices pane, expand the folder hierarchy, select an NF device, and click View Changes.
- In the Configuration changes pane, click Save to File.
- In the dialog, click OK to download the information in the format of a comma-separated values (CSV) file to your system.
