View Top 20 CPU Usage
- Expand the Dashboard Manager slider and select Summary view.
In the
			 Top 20 CPU
				Usage dialog box, a summary of the top 20 devices with the most
			 current percentage of CPU utilization is sorted by the descending percentage of
			 CPU utilization. Mouse over each device to see additional information.
The CPU (%) column displays the percentage of the CPU utilization, followed by a colored bar, which corresponds with the CPU usage percentage. The greater the percentage, the longer the bar. A red bar indicates a warning that CPU usage is between 90% and 100% and a green bar indicates memory usage is below 90%.
