SIP Interface
The following table lists SOAP attributes and sub-elements for the SIP interface.
| SOAP Attributes/Sub-elements | ACLI session-router->sip-interface | Default Values | Valid Values | SBC Version |
| state
RealmID * trustMode SIPConfigurationSIPPort address *# port *# transProtocol *# anonMode proxyMode redirectAct contactSip telUri fqdnDomain natTraversal natInterval regMinExpire regInterval registrationCaching isRouteReg SIPConfigurationCarriers acliObjectName *# options |
state
realm-id trust-mode sip-port address port transport-protocol allow-anonymous proxy-mode redirect-action contact-mode teluri-scheme uri-fqdn-domain nat-traversal nat-interval min-reg-expire registration-interval registration-caching route-to-registrar carriers options |
enabled
<realm> all 5060 UDP all none disabled none 30 300 3600 disabled disabled |
enabled/disabled
<realm> all, agents-only, relam-prefix, registered ipv4 1025-65535 UDP or TCP all, agents-only, realm-prefix, registered, register-prefix empty, proxy, redirect, record-route, stateless empty, proxy, recurse none, maddr, strict, loose enabled, disabled none, always, rport 0-999999999 1-999999999 0-999999999 enabled/disabled enabled/disabled list of carriers list of options seperated by comma |
4.0.0 and above |
| natmaxInterval
natIntervalIncrement natTestIncrement sipdynamicHnt |
max-nat-interval
nat-int-increment nat-test-increment sip-dynamic-hnt |
3600
10 30 disabled |
enabled, disabled | |
| stopRecurse | stop-recurse | 401,407 | list of response codes, 300-599 seperated by comma | |
| portMapStart
portMapEnd |
port-map-start
port-map-end |
0
0 |
0, 1025-65535
0, 1025-65535, end>start |
| trustMode
extPolicyServer defaultLocationString imsFeature NetworkID anonymousPriority termTgrpMode chargingVectorMode chargingFuncAddrMode ecfAddress ccfAddress operatorIdentifier inManipulationId outManipulationId |
trust-mode
ext-policy-server default-location-string sip-ims-feature network-id anonymous-priority term-tgrp-mode charging-vector-mode charging-function-address-mode ecf-address ccf-address operator-identifier in-manipulationid out-manipulationid |
disabled
None None pass pass |
all, agents-only, relam-prefix, registered,
none
empty or <pol-server> enable/disabled NONE (4.0.1), none (4.2), normal, non-urgent, urgent, emergency none, iptel, egress-uri none, pass, delete, insert none, pass, delete, insert Ipv4 or hostname Ipv4 or hostname empty or <sip-manipulation> |
| implicitServiceRoute | implicit-service-route | disabled | strict, enabled, disabled | 4.0.1 and above |
| tcpNatInterval
isSecure rfc2833-mode rfc2833-payload maxConnPerPeer maxConn idleConnTimeout SIPConfigurationSIPPort transProtocol tlsProfile |
tcp-nat-interval
secured-network rfc2833-mode rfc2833-payload per-src-ip-max-incoming-conns max-incoming-conns inactive-conn-timeout sip-port transport-protocol tls-profile |
90
disabled transparent 101 0 0 0 |
0-99999999
enabled, disabled transparent, preferred 96-127 0-20000 0-20000 0-999999999 UDP, TCP, TLS <tls-profile> if TLS specified |
4.1.0 and above |
| constraintName
constraint-name
disabled | empty or <session-constraint>
strtict, enabled, disabled |
4.0.1; 4.1.1 and above |
| responseMap
localresponseMap |
response-map
local-response-map |
empty or <sip-response-map> | 4.1.1 and above | |
| trans-expire
invite-expire max-redirect-contacts rfc2833-mode |
trans-expire
0-999999999
0-999999999 0-10 transparent, preferred, dual |
| untrustedConnTimeout | untrusted-conn-timeout | 0 | 0-999999999 | 5.0.0 and above |
| tcp-keepalive
chargingFuncAddrMode enforcementProfile |
tcp-keepalive
charging-function-address-mode enforcementProfile |
none
pass |
none, disabled, enabled
none, pass, delete, insert, delete-and-respond, insert-reg-cache empty or <enforcement profile> |
4.1.4; 5.1.0 and above |
| add-sdp-invite
SIPInterfaceMediaProfile |
add-sdp-invite
add-sdp-profile |
disabled | disabled, invite, reinvite
list of media profiles |
4.1.4; 5.1.1 and above |
| referCallTransfer
routeUnauthorizedCalls description |
refer-call-transfer
route-unauthorized-calls description |
disabled | enabled, disabled
empty, defined SA or SAG |
5.1.1 and above |
| implicitServiceRoute | implicit-service-route | disabled | strict, enabled, disabled, absent, replace | 6.0.0 and above |
| chargingVectorMode | charging-vector-mode | pass | none, pass, delete, insert, delete-and-respond | 6.0.0M1 and above |
| imsAkaFeature
imsAkaProfile hmrString SIPConfigurationSIPPort transProtocol |
ims-aka-feature
ims-aka-profile manipulation-string sip-port transport-protocol |
disabled
UDP |
enabled, disabled
<ims-aka-profile> or empty UDP, TCP, TLS, SCTP |
6.1.0 and above |
| sipProfile
sipIsupProfile manipPattern |
sip-profile
sip-isup-profile manipulation-pattern |
empty or <sip-profile>
empty or <sip-isup-profile> |
6.2.0 and above | |
address *# |
sip-port
address |
ipv4, ipv6 | CX6.2.0 and above |
