DeviceInfoObject
DeviceInfoObject is a data structure that contains the information necessary to add a device to NNC system.
- Arraylist<String> deviceIPList
- String username
- String Password
- String communityName
- int snmpPort
- String deviceGroupName, which will be the full path of device group, if we have a device group (groupAA1) under group1/groupAA, the client need to pass group1/groupAA/groupAA1
- WebServicesProtcolEnum, which is a enumeration contains (HTTP or HTTPS), this piece information is only used by 2600 series device.
- WebServicesProtcolEnum webServicesProtcol, this piece information is only used by 2600 series device.
