Local Policy
The following table lists SOAP attributes and sub-elements for local policy.
| SOAP Attributes/Sub-elements | ACLI Session-router->local-policy | Default Values | Valid Values | SBC Version |
| routeName *
LocalPolicyFrom # addr *# LocalPolicyTo # addr *# LocalPolicySourceRealm # acliObjectName *# activateTime deactivateTime state anonymousPriority LocalPolicyAttribute policyName * state startTime endTime dow cost LocalPolicyMediaProfiles acliObjectName *# carrierName nextHop # destRealm # appProtocol replace |
from-address
to-address source-realm activate-time deactivate-time state policy-priority policy-attribute state start-time end-time days-of-week cost media-profiles carrier next-hop realm app-protocol replace-uri |
* * enabled none enabled 0000 2400 U-S 0 SIP enabled |
Route0, Route1……
+number, number, *, fqdn, ipv4 or 0.0.0.0 same * or <realm> yyyy-mm-dd-hh:mm:ss yyyy-mm-dd hh:mm:ss enabled/disabled none, normal, non-urgent, urgent, emergency RP0, RP1….. enabled, disabled 0000-2400 0000-2400 M, T, W, R, F, S, U, H or any combination 0-999999999 list of media-profiles <media-profile> <carrier-code> SAG:<sag>, <sa>, ipAddress, FQDN empty or <realm> SIP or H323 enabled/disabled |
4.0.0 and above |
startTime endTime dow cost LocalPolicyMediaProfiles acliObjectName *# carrierName nextHop # destRealm # appProtocol action isTermRoute replace |
policy-attribute
start-time end-time days-of-week cost media-profiles carrier next-hop realm app-protocol action terminate-recursion replace-uri |
0000
0000 U-S 0 SIP none disabled |
0000-2400
0000-2400 M, T, W, R, F, S, U, H or any combination 0-999999999 List of media-profiles <media-profile> <carrier> SAG:<sag>, <sa>, enum:<name> empty or <realm> SIP or H323 none, replace-uri, redirect enabled/disabled |
4.0.1 and above |
| LocalPolicyFrom #
addr *# LocalPolicyTo # addr *# |
from-address
to-address |
also support 12*34, **** for number (potsstar) | 4.0.1, 4.1.1 and above | |
nextHop |
policy-attribute
next-hop |
SAG:<sag>, <sa>, enum:<name>, lrt:<name>, enum:<name>;key=<value>, lrt:<name>;key=<value>, ipAddress, FQDN | 4.1.1 and above | |
nextHop |
policy-attribute
next-hop |
SAG:<sag>, <sa>, enum:<name>, lrt:<name>, enum:<name>;key=<value>, lrt:<name>;key=<value>, ipAddress, FQDN, ldap:<name> | 4.50 and 4.5.1 | |
| description | description | 5.1.1 and above | ||
methods LocalPolicyFrom # addr *# LocalPolicyTo # addr *# |
policy-attribute
methods from-address to-address |
space seperated list of INVITE, REGISTER,
PRACK, OPTIONS, INFO, SUBSCRIBE, NOTIFY, REFER, UPDATE, MESSAGE, PUBLISH
also supports DS: 123#456*Ab (alpha-numeric-dtmf, a combination of A-D, a-d, 0-9, #, *) (potsstar) |
6.1.0 and above | |
| LocalPolicyFrom #
addr *# LocalPolicyTo # addr *# LocalPolicyAttribute eLocStrLkup eLocStrMatch lookup nextKey |
from-address
to-address policy-attribute eloc-str-lkup eloc-str-match lookup next-key |
* disabled single |
+number (e164), number(pots), num**num
(potsstar), */fqdn/ipv4/0.0.0.0 (hostname), DS:[A-D][a-d][0-9]#*(potsstar),
urn:service:[sos, sos.fire, sos.animal-control] (hostname)
enabled, disabled 24 chars such as noc, lac, line-code single, multi $TO, $FROM, $PAI or any string |
6.2.0 and above |
| LocalPolicyFrom #
addr *# LocalPolicyTo # addr *# LocalPolicyAttribute nextHop |
from-address
to-address policy-attribute next-hop |
(potsstar), */fqdn/ipv4/ipv6/0.0.0.0 (hostname),
DS:[A-D][a-d][0-9]#*(potsstar), urn:service:[sos, sos.fire, sos.animal-control]
(hostname)
SAG:<sag>, <sa>, enum:<name>, lrt:<name>, enum:<name>;key=<cic|rn|value>, lrt:<name>;key=<cic|rn|value>, ipv4, ipv6, FQDN |
CX6.2.0 and above |
