previous
Configuration - Market Codes (cf_marketcodes with CFG4.FMX)
The Configuration report for Market Codes will display all Market Codes that have been configured in the application. When the OPP_MHOT Opera Property Management Multi Property Base add-on license code is active, this report will represent Market Codes for the selected Property only.
Market Codes are configured in System Configuration>Rate Management>Codes>Market Codes.
Selection Criteria
Active. Select the check box to include active market codes in the report.
Inactive. Select the check box to include inactive market codes in the report.
