previous
Configuration - Revenue Buckets (cf_revenue_buckets with CFG8.FMX)
The Configuration report for Revenue Buckets will display the transaction codes associated with the various Revenue Buckets. When the Profiles>Profile Revenue Buckets application function is active, the user can configure and see the generated Reservation History revenues by configured buckets. This is accessed in Profile>Options>History>Revenue.
Revenue Buckets are configured in System Configuration>Cashiering>Revenue Buckets.
Transaction Code. The report output will display with the Revenue Bucket and a string of Transaction Codes.
Transaction Code and Description. The report output will display both the Transaction Code and Transaction Description within each Revenue Bucket.
