Configuration � Transaction Codes by Transaction (cf_trxcodes2 with CFG6.FMX)
The Configuration report for Transaction Codes will display all Transaction Codes that have been configured in the application. The report information will be in numerical order by Transaction Code.
Transaction Groups, Sub Groups, and Codes are configured in Configuration>Cashiering>Codes.
Transaction Group. Select the down arrow to select the transaction code group to filter by.
Transaction Subgroup. Select the down arrow to select the transaction code subgroup to filter by.
Transaction Code. Select the down arrow to select the transaction code to use in the report.
When the OPP_GCA PTS Gaming and Comp Accounting license code is active, a check box to Include Comp Transaction Codes is displayed to allow further filtering for the report output.
