previous
Configuration - Application User Setup (cf_users with CFG4.FMX)
The Configuration Report for Application User Setup will display all users that have been configured in the application for the current property, users at properties to which the current logged in user has property access, and users who have access to the logged in property.
The User Setup can be found under the menu Setup > User Configuration.
Selection Criteria
Filter
User. Multi-select LOV for filtering on specific users for the current property, users at properties to which the current logged in user has property access, and users who have access to the logged in property.
Include
Active. Select this check box to display active users in the report. This is the default. When the check box is unselected, active users will not be displayed in the User LOV.
Inactive. Select this check box to display inactive users in the report. When the check box is unselected, inactive users will not be displayed in the User LOV.
LDAP. Select this check box to include users configured for LDAP access to OPERA. This option is selected by default. See LDAP Integration for details.
