previous
Configuration - Waitlist Priorities (cf_waitlistpriorities with GENREPPAR.FMX)
The Configuration report for Waitlist Priorities will display all Waitlist Priorities and their defined sequence order to display.  The configuration item is only available if the Function WAITLIST is active.  When placing a Reservation on Waitlist, the user must select a Waitlist Reason Code, Waitlist Priorities are not mandatory.
Waitlist Priorities are configured in System Configuration>Reservations>Codes>Waitlist Priorities.
