CONFIRMATION LETTER TO PARTNER SOLUTION Application Setting
Group. Reservations |
Type. Parameter |
Application. |
PMS (Property) |
Description. When enabled, all confirmation letters will be emailed to a partner solution.
Internal Name. CONFIRMATION_LETTER_TO_PARTNER_SOLUTION
Property Determination. When active, the RESERVATIONS > PARTNER EMAIL ID FOR CONFIRMATION LETTER application setting appears.
Note: Confirmation letters are customizable reports. Hotels can customize the report layout and add or remove fields per their requirement.
Activation / Inactivation Rules. |
<none> |
Available Values. |
Y-Yes N-No |
Add On Licenses/Country Specifics. |
<none> |
Other Application Settings. |
<none> |
Affected Areas
Menus / Screens / Fields. |
<none> |
Reports & Report Forms. |
<none> |
Permissions. |
<none> |
Notes. |
<none> |
