previous
Detailed Availability (detail_avail with GEN2.FMX)
The Detailed Availability Report displays availability based on room types for a specified date range. The report can reflect either Availability or Occupancy. This information is pulled directly from the Detailed Availability screen (Ctrl+F2).
Displayed values on the report output are populated from the following tables:
Selection Criteria
Date Range. Enter a Date Range for the availability.
Filter
Room Class. Multi select LOV for filtering on specific Room Classes. The Room Class filter is only displayed when the GENERAL > ROOM CLASS application function is active.
Room Type. Multi select LOV for filtering on specific Room Types. Only include those reservations that have the selected Room Types(s) attached to the reservation.
Display
Availability. Select for availability information.
Occupancy. Select for occupancy information.
Include
Non Deduct. Select to include Reservations or Blocks with a Non-deduct status in the figures.
OOO Rooms. Select to include rooms that have been placed OOO in the Availability figures. This means the number of rooms available will subtract the rooms placed OOO.
Overbooking. Select to include those rooms that have overbooking the hotel in the figure. This means the availability figures might be represented with a negative (-).
Master Allocations. When the BLOCKS > MASTER SUB ALLOCATIONS application function is set to Y, select this check box to include Master Allocations in the report.
Example
The property has no arrivals, no in-house guests, no out of order or out of service, and 100% availability (155 rooms).
Two blocks with these details are created:
If the Availability option is selected and the following:
Report Output
