previous
Corrections and Canceled Payment (fincorrectionscalpay)
The Corrections and Canceled Payments Report displays all corrections by Cashier ID and can be run by transaction code range. This Journal displays all same-day reversals (debits) made to posting slips. Adjustments are made to previous days postings, or claimed revenue. Cashiering and Accounting departments can print this journal after making reversals to double-check their work.
Selection Criteria
From Cashier No. Single select LOV to choose the beginning cashier to start the report criteria with. All cashiers are included if left blank.
To Cashier No. Single select LOV to choose the final cashier to end the report with.
From Trn. Code. Single select LOV to select the beginning transaction code. All transaction codes will be selected if this field is left blank.
To Trn. Code. Single select LOV to select the ending transaction code.
